MiniMillMachinist
- Aug 30, 2022
Hi guys, just wondering if I could get some input on this face finish before my machine exits warranty! Doesn't matter whether I'm facing with my 40MM indexable cutter, or a 50MM face mill, with a slow feed I get a distinctive pattern in my face passes which follows the same pitch as the ballscrew (6MM).
I've seen similar results from other machines when facing and both the lead and trailing side of the cutter are making contact with the workpiece, but the pattern does make me question whether it's normal. For what it's worth, I had my machine ball barred a few months ago (my machine has always done this when facing) and the ball bar looked great. I assume this is due to minor twist in the ballscrew affecting the feed ever so slightly, but I'm not entirely sure. Would love to get some input!
PS, please ignore the fact the part was hanging out of the vice - this was just a piece of scrap I used to demonstrate the problem. It exists with all my parts depending on the location on the machine table.
Machine is a Haas Mini Mill
