Jogensen conveyor seems to have chips stuck underneath anyone know an easy remedy
VisionPDR
Jun 29, 2022
I have pulled conveyor out of machine and cleaned out tank and chips off of belt. The belt will not move forward or backward. I fear there are chips stuck underneath the belt. Any thoughts on an 'easy' remedy?
Ox
Aug 27, 2002
West Unity, Ohio
Prolly got something figgered out by now, but if it was a Turbo Conveyor, I would say that you dropped a spacer and it got pinched. A Jorgensen is likely the same problem, but I've never had that issue with a Jorgensen.
Just gotta force it. Most likely backwards.
On my Turbo's (POS's) when they start to git stuck like that, I run backwards for some time, and then you can hear a spacer(s) jingle around up in the head end, stuck inside. I drill a 3/8" hole, then a 3/4" EMT knock-out, and then you can see up in there, and reach in with a magnet/stick to fetch the offenders out.
Think Snow Eh!
Ox
Ox
Aug 27, 2002
West Unity, Ohio
I know that the OP has pulled a Garbo, but thought that I would add a pic to show what I have done to all of my Turbo's.
Pop that hole behind the pillow block there, and run it backwards for a while, and it will bring your MIA bushings up to the top and they will get caught in the endless hamster wheel, and then you can fetch'm out with a magnet.
If you are not the adventurous type, it is OK to turn the conveyor off while using the magnet.
Or even run it back FWD for a few inches to bring them back to view.
Think Snow Eh!
Ox
