BlueSky
- Jun 10, 2006
- Northern Front Range Colorado
I have a new to me K&T #2 HL Universal Mill, serial number 15-5147. I have a couple of questions that might be related. I have a K series parts manual which doesn't seem close enough, so some of the terms might wrong. I just ordered a parts and operator manual for the H series.
Sorry for the long winded context.
While I was working on freeing up the overarms ( one for two ) I was seeing how the selector for the feed speed worked. I could pull and spin the knob and move the selector around a quarter of the dial. I assumed the other part of the dial needed to move ( secret button? ) I was told by the previous owner to just move the spindle around and the gears will mesh up and the lever should move.
1. Assuming the back half of the speed selector for the feed rate is suppose to move, how do I get to the other speeds?
The second problem might be causing the first problem. I was working on moving the spindle around and found the motor would not spin past a certain point in one direction. Despite moving the spindle around, I could never get the selector to move any more than previously. Next, I thought the problem might be in an individual axis. So move X and Y around and engage the feed lever in both direction... The Z axis does not move, I don't put a lot of weight on it, but enough to convince me it is stuck. Ok, I have power feed, let's hook up the power and see if I can move the knee that way. Now is when I find out that the direction that the motor does not spin past is the direction it should spin. I try "backing up", power up and the spindle rotates and then stops again. Ouch, don't like that.
So, if I leave the spindle gear selector in between gears ( neutral ) and spin the motor, I get the same behavior, without the spindle spinning. So, I don't think the problem is in the drive for the spindle.
2. So, question number two is how do I diagnose this problem?
One last data point, I had forgotten to place a block under the knee before transport. I had the block, remembered it and then got side tracked during loading. It was lowered to help with loading.
Steve
Steve
