jccaclimber
- Nov 22, 2015
- San Francisco
I've used planetary lappers with cast iron plates and SiC abrasive in the past. I'd like to understand the process a bit better, and am using hand lapping to get some practice with the fundamentals.
Question 1: Low speed tool sharpeners like Glendo/Accu-Finish have a smooth ceramic plate as the lap when using diamond slurry (different from the plated diamond wheels usually used). I've made the mistake of using a harder lap than my workpiece with diamond paste and had issues with embedding diamonds in my steel workpiece. I don't remember this ever being an issue when using the ceramic lap on the Accu-finish, which I assume is much harder than my workpiece as well. Is there something special about the ceramic, or is it just that I've never noticed the diamonds embedding?
Question 2: With steel workpieces, is there any benefit in using copper vs. cast iron for the lap so long as my steel workpiece is harder than the cast iron? With cast iron would gray vs. ductile matter? If I need to go copper am I going to see much difference between tempers and alloys, or is this a case where close is well close enough?
