Large train derailment in Ohio.
Freedommachine
May 13, 2020
I think it's time to nationalize the railroad system here in the US. Private industry seems to be not very trustworthy.
And federal agencies are?
I would agree some improvement is in order but if it was nationalized, it would just become another bottomless pit for taxpayers while companies like NS reap all the savings.
Maintenance of national infrastructure is all farmed out to contractors anyway. The government would nationalize it and hire NS as the contractor to maintain it.
Unless you see it different somehow?
evil monkey
Feb 5, 2023
Evidently many chemical tank cars involved. Photos look amazing.
https://www.washingtonpost.com/tran...ohio-train-derailment-investigation-hotboxes/. Apparently a hot roller bearing caused his wreck and either the hot problem was ignored or the detectors were not working. Hot boxes became an old problem after railcars stopped using bronze sleeve bearings and upgraded to rollers, so I am guessing the hotbox detectors were not maintained properly due to a rare over heating problem .
DDoug
Oct 18, 2005
NW Pa
DDoug
Oct 18, 2005
NW Pa
Yeah IIRC wasn't it detected and they were trying top slow down when it happened? Maybe better detection is a thing
No, my point was directed to "Hot boxes became an old problem after railcars stopped using bronze sleeve bearings and upgraded to rollers, so I am guessing the hotbox detectors were not maintained properly due to a rare over heating problem ."
Detectors are a new thing, to replace one of the many functions of the caboose.
BoxcarPete
Nov 30, 2018
Michigan, USA
The "guess" was that detectors were not properly maintained or functioning. The report states that the bearing in question was measured and found close to the limit but below the threshold for an alarm at one detector, then alarmed out at the next but it was slightly too late. It's just one of those worst-case scenarios. In Engineering you have the choice to either A: make everything work with the absolute worst possibility that you can think of, or B: can catch 95% or more of the real life conditions and spend half as much on the system. Even option A won't get all of them because the smartest engineer may still be wrong about the true worst case.
Using a government agency to mandate option A will increase cost burden significantly and perhaps decrease failures a little bit, but it makes us all feel good right? Because once we tell those greedy rail companies they have to run cargo safely to its destination, they'll do it!
jim rozen
Feb 26, 2004
peekskill, NY
"I would agree some improvement is in order ..."
Yeah and the Titanic hit a little ice.
The reason the hotbox detectors were ignored for the first two samples was the train crew was under the gun to deliver the goods on time or be fired. RR companies are all about the money.
Yes they should be nationalized becuase things are coming off the rails (literally) pretty often these days. Screw the RR company profits.
Freedommachine
May 13, 2020
I didn't know that. Can you post a link for a report containing this information?
What happens when a government you loathe gets control and messes it up... have you considered that?
How will they be held accountable? Other than a congressional investigation that wastes money and goes nowhere - there is no accountability and it becomes much harder to fire the director when government is involved.
DDoug
Oct 18, 2005
NW Pa
Joe will have the trains running on time...regardless of anything else...."They MUST run on time !"
"I love Amtrak, and I want it to go 250 mph
everywhere ! Same with the freight, 250 mph ! I'll show everyone !"
Rob F.
Aug 5, 2012
California, Central Coast
Im interested to read that article but it's behind a paywall. Can yoh copy/paste it here?
Try this site, txtify. I just put it in here and it worked, this is a good program to get around some paywalls. There are other similar sites as well, search here the txtify and you should find discussion mentioning others:
Sep 10, 2022
I shouldn't, because the Washington Post is garbage (Janet Cooke, Amber Heard, etc etc) but just turn off javascript and you can go there fine. If it cuts into their profits I'm all for it, just don't believe anything they say.
evil monkey
Feb 5, 2023
been around since bronze sleeve bearings so not a new thing, at least since the 70,s when the idea was related to me by a Southern RR dispatcher that I knew personally
