Years ago, we sent some hydroelectric turbine work up to a machine shop in Port Colborne, Ontario. The shop was named "Hymac". One of the deciding factors for our awarding the work to Hymac was that they had a vertical boring mill of sufficient capacity to handle the various parts of the turbines needing machine work.
Hymac had purchased a used Farrell (? on the manufacturer as my memory is a little hazy, call it a 'senior moment') boring mill, ex US Naval Shipyard, and had just gotten it up and running when they took on our work. The boring mill was located in a cavernous steel building which still had a crushed stone floor. The boring mill had been set on a new reinforced concrete foundation, levelled up and was ready to work. Our job went onto that boring mill with drop-lights strung up for lighting, and a temporary power feeder run to the drive. The drive on that boring mill, was, as I recall, a DC motor with a motor generator set. I got up to Hymac a few times to inspect and discuss various portions of our hydro turbine work. When they were machining certain portions of the work on the VBM, we asked them to loosen the hold-down studs and put a dial indicator on the work. I wanted to be sure things were not going to spring out of flatness or round when the clamping dogs were slacked off. To check the dial indicators, I got on the table of the VBM and they had it running at a very slow speed. I was literally walking backwards, facing the indicators which were mounted off the cross rail, watching the indicators as the table (with the job on it) turned under my feet.
Hymac also had another vertical boring mill that they were getting ready for use. This was made by King, and had come from General Electric of Canada. This VBM was capable of handling work as much as 60 feet in diameter. This 60 foot diameter figure was a bit deceptive, since the table was not 60 feet in diameter. The table was somewhat smaller, on the order of 30 + feet in diameter. Set in the foundations were sole plates with tapped holes. The upright side frames and cross rail could be moved to different positions relative to the center of the table. For larger diameter work, the side frames and cross rail made a very short chord across the 30 foot radius circle, though the table itself was not 60 feet in diameter. Larger diameter work would overhang the table. Hymac said they had work for this VBM that would require using it at nearly its full capacity, cutting some large radius's for movable span bridge parts. Hymac also said this particular boring mill had machined turbine parts for some of the largest hydroelectric turbines on the North American Continent. I never saw this particular boring mill running, and it hulked in the semi-darkness of that steel building, which had no permanent lighting at the time.
Years ago as well, we were shopping for a planer mill. Our search took us to a machine shop in Philadelphia, PA. This shop had moved its operations to a newer facility on the outskirts of Philadelphia. The shop's original name was Bissinger & Stein. They had gotten away from really heavy machine work and were concentrating on seals for gas turbines and jet engines, so had modernized the name to "Steinseal" as I recall. We bought a Cincinnati Hypro openside planer with two Yancey milling spindles from their old shop. In that same shop there was a really large vertical boring mill. It had to have had a table about 20 feet in diameter. This boring mill was made by Betts, if I recall correctly. It was so old that it had a 'peck type' drive for the various feeds (eccentrics working linkage to arms with pawls that advanced the feed by moving ratchet wheels). This VBM was covered in dust, dirt and pigeon droppings. It was operational, though had not been used in years. The word was Steinseal was going to sell the building, and the VBM was available, or was going to be scrapped where it sat. Seemed a shame, but it was a machine tool way too big to be moved unless the buyer was prepared to bring in riggers. We did run the planer mill for some test cuts, and they had to temporarily reconnect the power to it, as well as having the bridge crane available and running to dismantle and load the planer mill. It was an old brick shop building, had not seen work in a few years, and was mostly empty. The neighborhood was described by the Steinseal people as 'the crack belt'. When we arrived at the building, they opened the overhead door and we parked inside the building, having been advised not to park on the street or walk out there. I have no idea whatever happened to that VBM, probably long gone to the razor blades and the building either razed or converted to some other use.
