Laser Plate and Tube Cutter Combo
Halcyon
Jul 17, 2022
missing light enclosure. laser light is really bad.
I have seen the Eagle laser in action and only heard great things about them. head spinning fast and perfect cuts.
IIRC fiber lasers cause bad corneal damage(reversible), while co2 lasers are a higher wavelength and cause retinal damage(permanent).
IkeHarris
Jun 10, 2018
Ever so slightly backwards. The fiber lasers for cutting sheet and plate are 1070nm. Most stuff we can see through transmits this wavelength nicely like your eye so you can get retina damage, permanent. CO2 lasers used for same are 10,600nm wavelength. Most things we see through are like a brick wall to a CO2 laser. Your eye gets surface damage. Both quite bad. Safety rules are the same for both. The windows, glasses and goggles can be different.
Anthony Howe
Sep 25, 2021
I have a 3D Fablight 4k pulsed fiber laser that plugs into a 115VAC socket that cuts stainless sheet up to 3/16" and tubes to 2" in diameter. Cost was about 115k delivery included. I also have an N2 generator on site delivering @ 99.99% @ 140psi. soon attaching a booster compressor to store N2 in gas cylinders for high pressure cutting.
