Lathe - Running larger bar stock
rwskinner
Sep 22, 2015
Somewhere in Texas
I know plenty of folks that remove their hydraulic chuck and stick on a manual chuck for larger jobs when need be. Most leave their draw tube in there and just suck it back.
My lathe has a 3.125" Spindle bore, but with the drawtube and hydraulic chuck, the largest bar is 2.5".
I need to run some 3" bar, but not all the way thru the spindle, but around 3' sections.
Is it okay to remove the draw tube and hydraulic chuck, install my set-tru then just run it? IOW, will I hurt anything, or contaminate anything running with the draw tube removed? Coolant, Chips.... It seems like it should be fine but trying to avoid unforeseen disaster by asking.
Garwood
Oct 10, 2009
Oregon
You gotta pull the actuator completely off to do that. Whatcha gonna do with the actuator? Plug all the hoses and remove it?
rwskinner
Sep 22, 2015
Somewhere in Texas
Why do I have to remove the actuator for? Draw tube just unscrews. My bar stock won't run that far back to the actuator so it's I.D. isn't an issue. Why can't it just sit back there and idle?
Garwood
Oct 10, 2009
Oregon
How long is your drawtube? You said 3' material in the spindle. Most lathe spindles are a fair bit shorter than that. The drawtube screws into the front of the actuator. Actuator and rotary union are typically 12-18" long bolted to the rear spindle face.
If you can fit the length you should be fine. Drawtubes are often loctited into the actuator. Definitely use a tight fitting tool to take it out.
rwskinner
Sep 22, 2015
Somewhere in Texas
Thanks. I have 28" to the front of the actuator to the chuck jaws. So I can cut the material around 34" and should be fine. I have to cut lots of 7/8" thick parts so I will slice off about 5-6 or so then do a pull and repeat. Way less waste like that.
Milland
Jul 6, 2006
Hillsboro, New Hampshire
Good idea. Or maybe turn an aluminum slug with a couple o-rings and just shove it back there. That ought to keep crap out.
Agree, but make it Delrin, not Al. I'd also suggest putting a "knife edge" (like a hydraulic piston seal) on the side facing the chuck so that if you do get chips down the bore they get "scooped up" by the knife edge, rather than going in between the plug and the spindle bore.
