Lathe X Dials, Radius, Diameter, Count Up, Count Down
laminar-flow
Jan 26, 2003
Pacific Northwest
As far back as I can remember, I have used lathe dials that were diameter reading. Most of these were what I call reverse reading and count up when making the part smaller in diameter, which measures how much material is removed in diameter rather than the actual diameter of the part. When I acquired my Monarch 10EE around 1990, it had dials that had two sets of numbers on it that went the other way around. What a dream as one could do a cut, measure the diameter, then set the dial to that diameter. But apparently this was not the way Monarch intended because the accumulator dial on the X read the other way. Anyway, I used the Monarch like that until I installed a DRO which I set up to read Diameter and the part size, not how much material was removed. I do have a Schaublin 70 and it read in diameter but measured the material removed, not the part. I then made a new dial to read the part, not the chips.
Then I saw a Schaublin 102 slide that not only had "reverse" reading dials, but it was in Radius. What a complicated thing to use. Yes, it can be done, but you need paper and a calculator close by. The 102 was then set up with a DRO that read Diameter and what the part was, not what was cut off. What a dream.
Does anyone know of lathes who's X dial reads diameter and the part? In other words, count down when approaching the centerline and in radius?
Every CNC lathe I know including mine is set in diameter and the work is the centerline and zero. An X adjustment of plus 0.010 makes the part 0.010 larger.
Any historical conventions would be nice to know also.
William Lynn
Jan 26, 2023
Some CNC lathes can toggle between radius and diameter. At one time, our shop had two small manual Hardinge lathes, one had the cross feed in radius and the other diameter. Cut, measure and remember. And if you can't remember, mark with a Sharpie.
AlfaGTA
Dec 13, 2002
Benicia California USA
Manual machine dials have limited range unlike a DRO or CNC control.
Pretty hard to keep track of say cutting a 2" diameter step in an 8" diameter part on a dial trying to gauge by diameter..
Most machinists working manual think in terms of depth of cut, derived from material setup and tooling.....Hence the dial that registers in counting "up" when moving
into the part.
Cheers Ross
bigjon61
Mar 23, 2014
Nebraska
Quote: "An X adjustment of plus 0.010 makes the part 0.010 larger"
I'd like to see a video of that.
You're joking right?
I feel like people are on one side of the fence or the other with the DRO. I like to set it to work in the actual diameter of the part. I admit though, in our shop, I am the minority.
laminar-flow
Jan 26, 2003
Pacific Northwest
That was quite funny. It is the next CNC part that gets larger in Ø. In the 80's I used a Southbend that had a diameter dial but it read material removed. Hated it. Always read a 9 as a 1, 8 as a 2, etc. so I could set it to the diameter of the part and proceed. That is how I used my Schaublin 70 before I made a new dial.
John Garner
Sep 1, 2004
south SF Bay area, California
I'm not a fan of micrometric collars (commonly "dials") that are diametrically numbered, but I've been able to use them on cross slides.
On compound slides, diametric numbering is abhorrent simply because it is only diametric when the compound slide travel is parallel to the cross slide travel. I want to know how far a compound slide actually moves, no matter which way it points.
Feel free to take these comments with the proverbial grain-or-pound of salt; as I've said many times before, nobody has ever knowingly paid me to run a machine tool.
TGTool
Sep 22, 2006
Stillwater, Oklahoma
I make quite a few larger, replacement dials for a lathe that cannot be named here. People just have their own, preferred way of working so they can get standard (100 graduations) or direct reading (200 graduations) dials. No argument. You want it, you get it. Now I know that most of these customers are small shops with a single lathe, so if they know their equipment there's no confusion.
It's trickier if you work in a shop with multiple machines that you have to use and some are one way and some another, especially with a "different" machine you use infrequently. Yeah, I know there are a lot of tougher problems in shops but sometimes it's the little aggravations that get to you.
