laminar-flow
- Jan 26, 2003
- Pacific Northwest
As far back as I can remember, I have used lathe dials that were diameter reading. Most of these were what I call reverse reading and count up when making the part smaller in diameter, which measures how much material is removed in diameter rather than the actual diameter of the part. When I acquired my Monarch 10EE around 1990, it had dials that had two sets of numbers on it that went the other way around. What a dream as one could do a cut, measure the diameter, then set the dial to that diameter. But apparently this was not the way Monarch intended because the accumulator dial on the X read the other way. Anyway, I used the Monarch like that until I installed a DRO which I set up to read Diameter and the part size, not how much material was removed. I do have a Schaublin 70 and it read in diameter but measured the material removed, not the part. I then made a new dial to read the part, not the chips.
Then I saw a Schaublin 102 slide that not only had "reverse" reading dials, but it was in Radius. What a complicated thing to use. Yes, it can be done, but you need paper and a calculator close by. The 102 was then set up with a DRO that read Diameter and what the part was, not what was cut off. What a dream.
Does anyone know of lathes who's X dial reads diameter and the part? In other words, count down when approaching the centerline and in radius?
Every CNC lathe I know including mine is set in diameter and the work is the centerline and zero. An X adjustment of plus 0.010 makes the part 0.010 larger.
Any historical conventions would be nice to know also.
Schaublin Dials, why are they backward in X and some are Radius instead of Diameter
After dealing with my Schaublin 70 English dial reading the material removed diameter instead of actual diameter of the part, (I would always use it to show diameter of the part by thinking of a 8 as a 2 and a 6 as a 4, etc.), I finally made a new X dial. I also have a Metric Slide and not only...
www.practicalmachinist.com
