TonyW@Bassett
- May 30, 2014
- Pennsylvania
Bassett Industries has an immediate need for CNC machinist's and Lead CNC Machinists (Tube Bending & Tube Fabricating Services – Bassett Industries, Inc.)
Lead Machinist salary $40,000-$50,000
Key Skills and Competencies:
• Minimum 5 years experience preferred in set-up of CNC lathes, CNC horizontal milling and CNC vertical milling machines
• Experience with reading and editing G code will be expected.
• Knowledge in use of precision measuring instruments and the application of such instruments. Instruments should include but not limited to calipers, ID and OD micrometers, depth gages, indicators and scales.
• Strong understanding in blue print reading/ geometric tolerance interpretation.
• Intermediate knowledge of tool holders, cutting tools, boring bars, fixtures, inserts and other accessories used on various machines.
• Must be able to follow written and oral instructions.
• Must be adaptable to a changing work environment, competing demands and is able to deal with frequent change, delays or unexpected events.
• Must possess basic math skills to include but not limited to adding, subtracting, multiplication, division, geometry and algebra for the purpose of calculating material fabrication.
• CNC programming a must
• Past experience with Haas machines a plus
• Solid Cam experience a plus.
Responsibilities and Accountabilities:
• Responsible for operation, loading parts, proving programs, operating controls, setting offsets, deburring and inspection of quality parts for conformance to requirements.
• Studies and interprets drawings, manuals, specifications or sample parts to determine dimensions and tolerances of finished work pieces, sequence of operations and set up requirements.
• Detects equipment malfunctions or out of tolerance machining and adjusts machine, within capabilities, controls or control media as required to insure quality of productions. Reports all machine malfunctions to Management.
• Communicates with management, production control, quality and other shop personnel for assignments and to resolve machining or quality issues.
• Responsible for keeping equipment and work area clean and orderly and perform basic preventative maintenance functions on equipment.
• May perform other duties as assigned by management.
• Lead 2 or 3 operators to ensure productivity, quality and standards are met.
Work hours are:
1st: 6:00 am- 2:30 pm with the opportunity for over time when the work load permits.
2nd: 2:30 pm-11:00 pm with the opportunity for over time when the work load permits.
Must pass a pre-employment drug test
Excellent benefits including medical, vision, life insurance, vacation, holidays and 401K.
Work hours are:
