markz528
- Sep 25, 2012
- Cincinnati
We have an early 80's Leblond lathe with a disc brake. We moved the lathe, and when setting it up in new location I did some quick checking of the voltages in the cabinet.
I was very surprised to find only 30 VDC going out to the disc brake (I would expect 50 volts DC on a 120 volt AC single phase half wave rectifier - am I correct?). Its got a selenium diode with 2 parts - one is a half wave rectifier feeding the brake coil and the other half is a free wheeling diode across the coil. There is also a capacitor across the coil. I tried to measure the voltage across the diode with a Fluke diode checker, but both parts just said OL. I don't know much about selenium rectifiers but Google tells me that a typical failure mode is increased forward voltage drop. Is this one going bad?
But the manual says the brake is 90 VDC (can't access the brake nameplate). Would they feed the brake with half wave even though its rated 90 VDC? Can I put a modern silicone diode on it and be done with it? Any concerns?
Thoughts?
Thoughts?
