jdavi581
- May 27, 2011
- Marathon City WI, USA
Hello,
I have been working on cleaning up a 1954 model X, and as I start making chips, I am noticing the feeds are not what I am expecting them to be. I looked at the change gears, and found the machine had been set up for leads, not for feeds/threads. I swapped a gear to a different input shaft to the change gear box, but it still is not working right. I am getting the following errors:
Feed Attempted Actual Feed
23.4 58
25.0 64
26.8 68
lever positions:
(The lever has 3 positions, A, B, C, B being half the output spped of A, and C is a quarter the speed of A.
The ratio lever is before the change gears, and is a 1:1 or 1:8
The dial has positions 1-10)
Lever: A, ratio Lever 1, for all, dial at 10, 9, and 8.
So something is off by ~2.5 ratio.
The output shaft from the ratio box has a 36 tooth gear, intermediate shaft has a 72 outside and 48 inside, and the input to the lover gear has a 48 tooth gear. According the the tag, these are the standard gears, and can be re-configured 4 different ways, but I have installed them as shown on the first line of the attached photo.
What am I missing?
Joe in WI
23.4 58
25.0 64
26.8 68
lever positions:
What am I missing?
Joe in WI
