hennebury
- May 27, 2009
- Ontario, Canada
I am new to metalwork, so I will ask for your indulgence.
I rebuild old woodworking machinery, make a few parts etc.
I have a DSG lathe and a surface grinder
I need to make half a dozen small machine shafts for some old machines that I am rebuilding.
The shafts are usually pretty beat up when I get them, so I am going to have a shot at making new ones.
The Original shafts are DIN 1.6582 (34CrNiMo6)
I plan on using this 4340 for the new ones.
They have three bearing journals on the axis and an double bearing journal offset.
My thoughts were to turn the shaft down to 24mm finished size, make a collet with the offset bore to hold the dressed rod, use that collet in the Jacobs chuck, machine the offset, then finish in the Jacobs chuck with a standard collet.
This is the material that I was considering.
4340 HR HT BAR 285/363 BHN ASTM A434 CL BD
1-1/4 RD S/C 1'3.5" (15.5")
Any advice on the material or machining would be appreciated.
