Re: What could be causing this inconsistent reading?
Duh, this is normal. How many would do the extra revolutions and see it or wonder why?
So many do a one turn check and got it to zero. Go so far away from me.
The bearings do not to circulate in one rev.
Why do so many not understand this.? One rev can not check run-out. It is impossible if the system has bearings.
Air bearing fine, all others the cycle is different.
Can be two, five or the revs. It will repeat. Can be two and 3/4 reves dependent on bearings. It will repeat.
One also sees this in grinding spindles and surface finish.
