surplusjohn
- Apr 11, 2002
- Syracuse, NY USA
this is for a fine art printmaking application. ie engraving/ drypoint. i am looking for a cutter that would scrape fine lines into plexiglass. around 50 lines per inch, and an inch or so wide. EC Lyons makes an engraving tool called a half tone cutter that is the right idea, but only about 1/4 inch wide. I have one of these but need a wider tool. I don't know what it would be for but there might be a standard cutter for some other purpose that would fit the bill. could be tool steel or carbine, but this would only be used in acrylic or PETG or polycarbonate, never metal. and only used in a handheld tool holder. What i am doing is making clear plastic printing plates by scratching into the surface vs etching a metal plate. these plates are printed by forcing ink into the scratches and then wiping off the top surface so that only the scratches print. To print, heavy damp rag paper is placed on the plate with 3 layers of wool felt on top of the paper and then put through a roller press that forces the paper into the scratched grooves which picks up the ink. I imagen EC Lyons would make me a special tool but i wanted to ask here first, THanks
