Looking for info on OLD Clark Clipper
59Clipper
May 21, 2021
I have run out of ideas on the zenith carb. I also got a impcp ca100m-1 with the lift. Can I just drop that in place and just use the zenith vaporizer that is on it?
Yes, the Impco Ca100 is a propane mixer/throttle body. The vaporizer turns liquid propane into gas, the mixer/carb is the throttle control. Does the distributor still have points? Have you set the dwell? I have a 40 pound propane bottle with a hose and part of an old weed burner I can start any spark ignition engines to test.
You can get a hose that can feed the mixer from a BBQ or RV bottle maybe start from the mixer backwards to eliminate guessing.
john.k
Dec 21, 2012
Brisbane Qld Australia
Fixing old forks,I have noted that often the distributor is very worn on the shaft,and timing can vary widely,which is often a cause of no start,and if it runs ,no power......cure is a replacement electronic dizzy ....dont waste money with the car dizzy repairers,who charge hundreds,and stick a bit of epoxy in the bearings.....it wears out in a couple of weeks.
59Clipper
May 21, 2021
It still has points. I checked them, but I will do it again and I will also replace the plugs before I try the impco.
59Clipper
May 21, 2021
Is just getting the pertronix module workable or do you have to buy the replacement distributor. I haven't taken the distributor out yet to see if it is worn.
JoeE.
Aug 31, 2006
Kansas
As far as wheel cylinder kits... I just got through repairing the brakes on an old early '50's Hough Payloader.
No idea how long it sat, but the brake lines were severed and no fluid left in either wheel cylinder.
I disassembled each one. They weren't rusted bad at all. I just honed them out a little and went over to the NAPA auto parts place and asked if they still had the rubber wheel cylinder cups for sale.
Yep.
So, 10 minutes later I'm walking out with four 1½" diameter rubber cups. Put it all back together and it works~ no leaks.
So, don't order a kit, show the parts guys what you're needing and see if you can buy them individually like I did.
By the way, I've got a Clark Clipper that is a twin to the one Steve in SoCal has.
The distributor in mine is loose as a goose in it's bore. If you grasp it by hand, you can wiggle it around!
The tires are worn slick, no tread at all.
I just got through snooping on the web and found that I can actually buy replacement press-on solid rubber wheels.
The day after that I pulled up at an intersection next to a truck pulling a trailer with what I guessed was a forklift tire press.
I got the driver to roll down the window and asked him if that's what it was... "Yes". How much to press off and replace a set of 4 of these wheels on this little unit.
"You'll have to call the company and ask... they charge by the inch."
I've had to pull the mast cylinder off my lift. It was leaking past the piston seal and when you'd reach the end of the upstroke, it would ooze past the rod wiper and spray out all over the place.
I got ahold of a knowledgeable salesman at "Baum Iron" in Omaha and he asked me for some measurements and on what machine it was on... a few days later I had a seal in my hand and repaired my mast....Baum Iron is good people.
The little thing sure comes in handy. Here's a pic of me using it to place a big sheet of steel out front of the shop... I've got a steel driveway.
It had no connection betwixt carb and air filter (oil bath). The previous owner made one out of rubber radiator hose and exhaust tubing bent to fit. You can see the rubber hose in the second of the following pictures.
The gas tank was bad. He left it in place and made an external tank out of an old fire extinguisher.
The "tank" hangs on the rollover cage upright over the counterweight.
The original 6 volt battery is still setting down in there under the radiator... too much trouble to get out. I just put a regular automotive 12v. battery in it and it's laying in the counterweight on the outside of the radiator... held in place with a bungee cord.
It's got a Chrysler alternator with one of their electronic voltage regulators.
There's really no good way to take a good picture down in the engine compartment.
It has never had side doors that I know of.
59Clipper
May 21, 2021
The p.o. called me the other night and he found the sides for it. So I have going for me. I also discovered it was originally red.
You gotta show us what the elusive side covers look like. How long does the engine run when you start it? It really sounds like the fuel lock is closing. The coil is not expensive 10-15 bucks maybe change it on principal. The other thing, IF it has a condenser in the distributor change that.
Steve
alexashawn121
Banned
Jun 2, 2021
Yes, the car is getting fuel. It has that, just not wired incorrectly right now. In fact, I have a lot of work to do on the wiring.
neilho
Mar 23, 2006
Vershire, Vermont
Dwell gets to be all over the place, too, but it's simple enough for a machinist to rebush a distributor.
59Clipper
May 21, 2021
OK, I was going to do it anyway, so I ordered the pertronix conversion kit. FYI the number for it is 1142N6 for the 6v negative one. I also ordered a new Coil, cap, dust cap, rotor and wires.
Cap 811735 Delco no.
Rotor 820445 Delco no.
Dust Cap: ABC186 Steiner no.
I also ordered some Autolite 386 plugs.
So while I wait, I am going to start working on the wires.
59Clipper
May 21, 2021
Steve
Steve, here's your photographic evidence that the elusive side panels do exist.
The engine when started keeps running until I shut it off. I just can't start it again until it cools down and I fiddle with the carb again.
The cap and rotor had some grooves in them and the plugs were worn, so after next Tuesday, we will see if it was more of an ignition problem or if there is something else.
In the meantime, I dropped the starter. It is a Delco-Remy 1107735. As you can see from the picture, I need to replace the Bindix/Starter gear.
john.k
Dec 21, 2012
Actually ,thats pretty good for an old Bendix gear......its the flywheel that is often the problem.......well not the flywheel,but the ring gear....a four generally stops in one of two spots on the ring gear,teeth get chewed at these locations....Bendix spins wildly before engaging worn teeth,...the rest you know.
59Clipper
May 21, 2021
It's more of a problem with the bendix not engaging. I am going to keep my eyes closed on the ring gear for now. I don't really don't want to split it apart to replace it right now.
Hobby Shop
Mar 20, 2014
Michigan
I have the same issues with my old Clark. It will run for a couple of weeks with the choke on but eventually, you’ll only be able to idle around. If you hit the throttle, it will die and won’t start until it cools off. I’m at the point of replacing everything from the propane tank to the carb or converting it to gas.
Maybe this has already been mentioned but check your antifreeze, the regulator could be freezing up on you because it’s low.
