So I've got a large production order, and the parts are being made on a 2001 Mazak Integrex 100-IISY. I've been using 17-4 H900, and the customer lets me use annealed if the HRC is high enough from the mill.
The material is 1-5/8" in diameter, and the parts I'm making are much more of a mill application. I'm basically using the lathe as a bar-fed mill, and the part-off is my final hurdle to overcome. So here's the deal: I'm cutting a 3mm wide slot behind the part with a Sandvik QD stick tool, which leaves extra stock on the backside. I then come back in and mill away most of the excess stock that's surrounding my part to speed up the op2 process. Once that's done, I grab a 2mm parting tool and come in to pop off the part. The whole shebang takes about 5 minutes per part, and it runs great for a while but always blows up my parting tools.
I'm currently using the Sandvik 1125 QD CM inserts and running at 330 SFM & .0039 IPR. The weird thing is that I don't break the inserts on the cutting edge. I'm actually snapping the insert in the middle, and then all hell breaks loose. The tools are failing with absolutely no rhyme or reason. From what I can tell, the insert seats themselves are getting a lot of load, and they seem to be fatiguing pretty quickly, which ends up allowing for catastrophic failure.
What kind of parting tools do you like to use for materials like 17-4? I can make these tools work for a few days at a time, but the goal is to run 24/7 with sister tooling. I can't get that far with tools that fail sporadically.
