Looking for some connectors for Bridgeport Interact 720 project
num1bryanp
Nov 16, 2008
Idaho
Hello Everyone,
I am in the process of adding a 4th axis to my BP 720. But I am having a hard time finding some of the connectors I need to finish the project. The pictures below will show the connectors I am looking for.
1. I need one 6 pin male and one 3 pin male connectors to connect to the ones shown with yellow around them
DCBA Distribution board
2. Need one 6 pin female connector to connect to the one shown.
Fanuc AC servo driver A06B-6050-H102, top board power connector.
Inside connector dimensions 1.38 x .30
3. Need one female 9 pin Heidenhain flange connector like one in picture
Thanks,
Bryan
zurferjoe
May 12, 2022
Hi Bryan , did you get the 4th axis project up and running ? And if you did have you got the parameter code to get it all running ? My machine has the rotary table set up fo the 4th axis cables plugs and all , but I lost all of the parameters (check those batteries with the machine ON!! ) and with it the parameter for the 4th . So hope you can help , all the best Harry
