Hi guys I got this job finished now and just posting a follow up on how the Sandvik and Kennametal drills compared. The Sandvik 870 is the clear winner. It had no problem running at 0.012 IPR and gave me over 600 holes per insert, exactly what sandviks calculator predicted.
I had to run the kennametal drill at 0.007 IPR feed to avoid insert crumbling in the center, and then it struggled to get 400 holes per insert, and finally one of my kennametal drills jammed up and destroyed the whole drill part way through the job. The kennametal coolant holes exit about an inch back from the tip and this leaves the tip of the drill prone to rubbing and welding imo, poor design. The coolant holes actually push chips back towards the tip! I replaced this drill with another sandvik 870 and it ran WAY faster, quieter, cheaper per hole and seems to be much more reliable too.
