lost a couple of parts to a 9a
randysoo
Apr 8, 2022
I bought a pretty beat up 9a this spring, and I've been slowly tearing it down and cleaning and painting it. I've been reading and lurking to get as much info as I can retain over the months, but in reassembling the apron and saddle I've lost my saddle lock, and the retaining ring for the hand wheel pinion. If anyone out there has either for sale please contact me.
Randy
johansen
Aug 16, 2014
silverdale wa
Saddle lock... Consider moving it to the left hand side of the apron, especially if you are not going to rescrape the apron and grind the ways. It's just a plate with three raised areas for contact. There is room you could build a different kind of lock, actuated by something sticking out of the front of the apron which would be safer to use.
The reason I say this is because when you lock the carriage, it will lift the left side of the carriage up, unless everythig is perfectly flat. turning it into a tuning fork. Most of the time your tools are to the left of the compound slide.
randysoo
Apr 8, 2022
thanks for the advice. but, I'm not trying to build a better mouse trap. I'm trying to figure out the one I've got
randysoo
Apr 8, 2022
I made a pinion retaining ring from an old wire key ring. does anyone have the dimensions for the saddle lock?
randysoo
Apr 8, 2022
I was able to find a picture online. from there I made one from 3/8" bar stock. the original piece is 1/2" but I didn't have any around. luckily the dimensions aren't too critical so I was able to cobb this together with a 5" grinder with a cutoff wheel and a drill press
