M PLUS need to reteach spindle orientation
bonestock
Feb 6, 2012
Atlanta, Ga
Long story short - I had to pull the spindle motor on my VTC16 to troubleshoot noise issues. Now the spindle does not orient to the proper position needed for tool change.
I hope there is a procedure reteach or a parameter to correct it by a few degrees -- because I would rather not pull the motor off again.
bonestock
Feb 6, 2012
Atlanta, Ga
I love when you are solving the same problem again -- you can't remember how you did it the first time. Then google pulls up your own thread where you posted the solution. I need more coffee.
ewlsey
Jul 14, 2009
Peoria, IL
I've been there. There's a magical code that lets you see the "other" parameters. Then you have to orient the spindle where you want and enter the encoder reading into the parameter. I've done it on a few Integrex machines, but I have to call Mazak every time to walk me through it because I forget all the steps.
Jman223
Aug 17, 2022
1131 is the code for mazak on the correct page but you can get yourself into a bad spot if you just start changing things id make sure you have the machine parameter list
