machinable aluminum repair
drcoelho
Feb 19, 2017
Los Altos
I'm in need of fixing a botched hole in an aluminum part, looking for recommendations for compound that can fill in the hole and allow for re-machining of the hole, suggestions?
drcoelho
Feb 19, 2017
Los Altos
Prefer not to weld, just a small hole maybe 0.4" diam by 0.2" depth, just looking for something quick and easy, not too worried about strength.
Milland
Jul 6, 2006
Hillsboro, New Hampshire
A metal insert as above of the right size is probably a better move. If you "step" the insert such that the lower ~.15" is a few thou under the hole, and the remainder is a touch oversize you can get the retainer compound to hold it, but after press insertion and finishing have a near-perfect hidden repair.
AARONT
Feb 19, 2013
Madison, WI
Depending on the purpose of the hole we tend to machine it oversize about .15" or more per side than press fit a little longer plug in and machine it flat to the surface.
