I've just had a first iteration design machined. It's all within tolerance but on 6 internal diameter features they have hit the bottom of the tolerance to within 0.01mm on a range of 0 to -0.05mm and on the one external diameter they have hit the absolute max size. So my question is, they've obviously aimed to hit the minimum hole size and the maximum shaft size (unless it's some amazing coincidence on all 7 features), is there some practical reason that they've done this?
I'm a design engineer by trade and I've done a little bit of machining. I always aimed for the middle of the tolerance band by default. The assembly will still work (it's within tolerance) but I'm going to have a batch of these made and I'm wondering if I need to adjust the tolerance if they are always going to hit maximum material condition because it makes fitting a little bit more time consuming. I'm asking here just in case I'm missing something obvious before I speak with them again.
The work was done on a 3 axis CNC, not sure of the make.
