JoeCraftsman
- Mar 5, 2017
HELP - I'm having a hard time finding nice solid speeds and feeds for titanium using 5mm and 1/32 diameter end mills.
Any suggestions from anyone? I put my 'initial thoughts' below... please feel free to comment...
These machines have been working great and I've done a lot of 303 Stainless with .150 x 150 pockets @ .150 deep with 1/32 end mills no problems.
I have not done much small diameter milling in Titanium for a bit and don't want to go through the end mills
Here's the basics regarding Machines and just a couple parts details...
Chevalier QP2040-L
10k Spindles
One machine with Synergy 735 Coolant
One machine with Blasocut BC 35 NF
Part 1
Grade 5 Titanium
0.039 Wide Slot x 0.020 deep
Accupro End Mill, 1/32 Dia x 1/8 Loc ALTIN 4 FL
Part 2
Grade 2 Titanium
.164 x .164 Pocket @ 0.040 Deep w/ 0.010 Radius in Corners (+/- .005 on Corner Radius)
.5mm (0.0197 diameter) x 1.5mm Loc Uncoated 4 FL
I will be getting rid of the bulk with 5/64 end mill likely and may pre-drill corners with drill point .002 off bottom.
My initial thoughts for the slot part is 8500 RPM, .0002/tooth, 6.9 ipm at .006 doc. The RPM only because I don't usually run max, the rest just to be conservative hopefully to save the end mills and not rub them to death.
Thanks in advance!
Chevalier QP2040-L
10k Spindles
Part 1
Grade 5 Titanium
Part 2
Grade 2 Titanium
Thanks in advance!
