guythatbrews
- Dec 14, 2017
- MO, USA
I just got a HBY 590. One of the common issues discussed is the proprietary Cazeneuve spindle nose. A camlock spinde nose was an available option, but my machine has the Caz nose.
Hopefully this thread will finally arrive at a complete backplate but be warned it will take a while to get there. I'm starting now to help myself keep track of the stuff I learn and in so doing provide a reference for others.
Here is the rational for the nose from Mssr. Maurel, copied from the French site Usinages. I do not speak or read French but Usinages simply means Machining.
"The so-called "Cazeneuve" spindle nose appeared in 1949. Its design is based on a simple principle which ensures its high precision, to the detriment of some machining difficulties.
The front face of the spindle is flat and ground.
The external cone (about 7° from memory, but to be checked) is of large diameter.
A false plate is needed to adapt the chucks using the standardized centering provided on them.
How it works:
Centering is provided by the outer cone.
The three set screws are used to ensure the installation of the plate. as it is a cone there is a slight deformation of the metal and a pinching, which will ensure the training and the transmission of the power, without any effort on the screws.
To avoid bad centering it is useful that the flat surfaces just come into contact.
In a single operation we ensure the training and the centering by the cone, the cone being external and of large diameter, it allows to ensure important spindle passages, unlike the iso - camlock -classic nose (cone of small diameter - less precise and driving effort ensured by the fixing screws, hence constraints on the spindle
. training is effective. _________________ Jamawi"
How it works:
