xr4x4ti
- Nov 17, 2007
- Minneapolis, MN
Hello,
I am in need of making few splined shafts. I plan on making them out of 4140 or 4340 and heat treating them to 40-45 Rc. The longest one will be about 25in long, 1.125in OD and with a 1 module 27 tooth spline on both ends.
I have made splines before and I have carbide cutters. In the past I have always cut the splines on an existing part that was already hardened and the carbide inserts did the job no problem. My question is, should I rough out the shafts, leaving some stock, and then get them heat treated and cut the splines in the hardened state? I am concerned about the shafts warping after heat treat and having to be straightened. If I clean up the bearing surfaces by hard turning and cut the splines after heat treat, that will not be an issue.
Thoughts?
Related, do any suppliers provide 4140/4340 already heat treated to 40-45? 28-35 is quite common but a little soft for my application.
Thanks in advance,
Tim
Thoughts?
Thanks in advance,
Tim
