M. Roberts
- May 11, 2021
Hello all,
In MC 2018, I am trying to do a simple task; center drill and drill a hole...I want to CD the hole and leave a chamfer at the top after I drill it. I used the depth calculator, entered the desired diameter of the chamfer, and hit the overwrite button; the numbers it inputs into the depth is not correct...I cant figure it out. I do not have the "tip comp on". I am using a standard #7, 60 degree CD, and I would like the top of the hole to be 0.525" diameter....any thoughts...constructively speaking
Mark
Mark
