I don't have mill-turn, but their active reports is just not user friendly at all. X+ is 1,000x better for setup sheets. If it was better configured out of the box then it would be worth looking in to but as it stands, it needs way too much initial configuration to even begin to use it effectively.
I don't use the tool manager either because I really don't need it for what I do. I have messed with it here and there,but it just doesn't seem to have anything that would benefit me and how I use Mastercam.
My biggest beef....is when 'grammin, you (grammer) enter ALL the detail to do the job.
Tools, stickout, stock size etc.
It really should be 1x click, to get a workable tool list/set sheet outta it.
But it took a few releases (= years), before rotary axis was incorporated and also for stock to be able to be a diameter.
Yup, 3axis only, no hori....and material was output/specified as 1" RADIUS
This was after the big fanfare of the release....
I persevered and had CNC help me get a working tool list/set sheet and used to use it.
But also had to do any edits in NitroPro, as this was the best editing package I found, because CNC wouldn't pay AR manufacturers license to be able to save in MSWord format.
It was a registered enhancement request, and I kept banging on and on and on and on about it, but nope.
Yes, you can save as RTF, but that lost "lines and boxes" - yes you could save as HTML and then load into MSWord, but then the "lines and boxes" would disappear total ballache.
And what's the most import job of a 'grammer - passing the correct info onto the setup guy.
And it's all "in there", and
should be a couple of clicks....
Yes, +1 to Gunther and X+.
I had that configured showing each OP G54/55 etc, planes, coolant state etc etc.
1x click and REALLY EASY to double check there was no spurious G59 (or whatever) datums, and that I hadn't forgotten to activate coolant.
So I would 'gram, verify checking to model, 1x click X+, Post, run through NCPlot, and lastly create the set sheet.
Then we'd set, check tool lengths at the start of every tool, and just run it.
But that's thanks to independent X+ and NCPlot for confidence....
In X5 I had a tool library.
Went to X7 and the other 'grammer wouldn't use it because the graphics were crap (which they were - it was the first release of the new UBinterface where they changed manufacturers).
So I converted the tool library and then we were running on old X5 and new X7... Then came good 'ol X9 and there were some compatibility issues between 5/7 and it, but I then knew that 2017 and the re-write, would be losing tool library compatibility so it was start again.
I stayed on 9, beta tested the new, and sold the business....
The thing about the tool manager....it was conceived with no initial thought for a gauge line.
When this was pointed out and asked to be implemented, CNC said it was impossible because of the way the toolmanager database was written.
I have used 2020, but not looked at any newer release, so IDK if this has been addressed....
