UncleFrank
- Nov 14, 2015
- Midwest, USA
We're winding 3/16 steel rod around a 5/16 mandrel to make something that looks like a spring several inches long when completed. We're heating the wire red hot, with a torch I assume, as we wind it around the mandrel.
The mandrel has a partially thru hole close to the end, similar to the eye of a needle, to hold one end of the 3/16 wire as we wind it so there's only about 1/16 edge distance left on the 5/16 mandrel.
The eye end has broken off and the mandrel shows some degredation from heat. I suspect the original mandrel was 5/16 drill rod since that's readily available.
Is there a better material choice for the mandrel or a specific heat treating process for drill rod that might extend the life of the mandrel?
