eqshop9689
- Aug 31, 2017
I need to build some "Bull Pricks" This is basically a fancy spike or stake that they pound into the ground like a pilot drill bit, to make room to drive the wooden stake (hub) or vampire stake into the ground to set grade (elevation) when building roads.
What type of material do you guys think i should use?
I am going to build these on the lathe with the tapper attachment.
It will probably be a long tapered cylinder with some knurled handle and a large head on it for the hammer to hit.
What would be the best material to hold up to the years of being pounded into the ground. Also would like something that will machine nice.
Thanks for your input, advice and sharing years of experience.
