I always thought when I saw the first machine they came out with the size of the main frame would be good for a smaller sized machine. Looks like they had that in mind all along.
https://youtu.be/Nhc3eu3jM6E
Charles
I agree ~ doesn't look too bad.
I.e. smaller travels and
14" deep table would make it proportionately more rigid than the VC EZ 20 - (their 40 x 20 of the same EZ "Line". ).
[ Wonder if that really helps the ergonomics / reach into the machine + tricky set ups ? (Over the 40 x 20 ) or VCN 40/20's ].
15K rpm spindle option,
30" X travel; 16.14" Y travel and 20.08" in Z travel.
14.17" by 37.40" table.
VC-Ez 16 | Mazak Ez
^^^ Then click "Specs" tab in lower half of page.
Doesn't look too bad on floor space;
__________________________________________________ __________
Seems they (MAZAK - vid) emphasizes possibility of several 4th axis rotaries.
I.e. the control can handle 4th axis positioning (and maybe full 4th contouring ?).
^^^ This is an animation for the (VC EZ 20 - the 4020 version - ) showing 4th axis rotary applications.
_________
Sort of a HAAS done the MAZAK way ... ;-)
But that gets you pre-tensioned ball screws,
High bandwidth control,
MX roller slides/tucks,
etc.
Coolant options don't look too bad.
+ 50 tool option.
