Chips Everywhere
- Apr 29, 2021
I got a replacement pump for my Mazak QT 8, the pump can run on 1ph 115v or 1ph 220v. My machine has 3ph output at the pump connector at the electrical panel.
Should I be concerned with running the pump in 1ph 220v (5amp I think) configuration? My concern is that I’ll be pulling power from 2 of the 3 phases and possibly throwing something off balance, possibly affecting machine operation.
I’ve experienced this before on another machine, but when I had this issue it was a much larger amp draw (17amp I think) on 1 phase 115v and you would notice it on the spindle when the auxiliary compressor motor would kick on.
Any input is appreciated.
