Arc-On
- Sep 6, 2011
- Holland, MI
So, I have a 2002 Mazak Quick Turn 350 with the 640T Nexus control.
I'm having problems with the machine shifting the program with repetitive parts.
I'm making a simple part in delrin, its basically a fancy cap that goes over a seal. 3.25" diameter bar, the part basically looks like a large bottle cap. Real simple stuff, turn to diameter, drill, bore, put a groove in the OD, part off. I don't have a bar feeder/puller so in the past what I'd do is pull out maybe 8" of bar, and just have Mazatrol shift the program over 4 or 5 times and repeat while I go do something else, then I just manually pull out more bar and keep it going.
Today though it isn't shifting properly. Program is set up to repeat 5 times, each time shifting zero 1.405". The first part comes out fine, the second part comes out fine but the third part crashes. The tool we use for facing and turning seems to lose track of where it is in space and hits both the face and the OD in between the rough and finish passes.
It's weird, the tools all seem to be hesitant or "confused" for lack of a better word after the first part. On part one, all the tools go right to where they need to go for the start of the cut. On part two, the tools go to a point close to but seemingly unrelated to part geometry, pause a second, then go to the shifted start point. On part two, they don't crash or hit anywhere they're not supposed to be, but on part 3 the tool just seems to ignore the just cut part geometry and drives the tool right to where the start point is of the next op and hits the part in the process.
Any thoughts?
Any thoughts?
