Mazak Super Flow coolant how to use?
M Code
Apr 4, 2021
I have never used the high-pressure coolant before, anyway we have one machine that includes high pressure-coolant pump we run M 131 M100 to 106 to control the pressure. I plan to use the high-pressure while drilling.
As first time we use it.
Is there anything related to safety need to be considered?
We have CAT50 ATC, is there a specific holder we need to use or it's applicable for all ER, shrink fit, etc..?
Can we run M51 and M131 M106 together?
The outlet of the high pressure-coolant is from where? I observed it's not from the nozzles like M08, and not through like M51 either. this when run M131 M106 only.
Philabuster
Jul 12, 2006
Tempe, AZ
The outlet port of the coolant will be determined if you programmed M8 or M51. You can also use M8 and M51 simultaneously if you wanted as well.
Do not use M51 if the holder does not have through coolant ability like a side lock holder for example.
