Mazatrol T32-3 EIA programming codes for live tooling and C axis
Philabuster
Jul 12, 2006
Tempe, AZ
Appreciate it. Got a Patreon? Wouldn't mind chipping in some beer money.
So we mostly machine cast parts that'll have 3 or 4 lobes that get drilled so we need to teach a C0. I skimmed a couple videos but didn't see where I can set the C-offset for Gcode.
No Patreon. Thanks though. I do not think you can set a C-offset for the T32 control. I know I cannot do it on my T-3. Newer machines have that capability. Ghetto workaround is to put a pin in the live tool and then slide the part on the pin and then clamp the part in the chuck to get the C0 orientation on a previously drilled part.
Skubeesnak
Jan 14, 2014
Utah
you might be able to put your offset in as a first move in program. say GOX?Z?C(offset value) then use a G50 C0. it will reset zero to wherever its called from. then at end of program or before call G28H0 to reset home C
len Oneill
May 18, 2023
Could you tell me the g code for multiple spindle divisions, within a sub program or routine. 500 divisions
