MDI commanded Ttttt to move X axis, and Z MOVES too!!! Why?
doug925
Nov 21, 2002
Houston
I am linking a video of the problem.
Syntax changes to the command line do not make any difference. T080808 or T0808 etc...
(FYI, I have the Z max limit set 1" from crashing into the tailstock)
Sometimes it will move both axis, but not always.
I am confused, to say the least.
Can anyone shed some light on this?
Thanks,
Doug
Mike1974
Nov 5, 2014
Tampa area
Thanks,
Doug
Is the offset call automatically bringing Z to the zero maybe? Have you tried removing or changing your Z offset and see if that makes a difference?
doug925
Nov 21, 2002
Houston
I assume you mean removing the Z value in Tool Offset? (or do you mean face of the part, offset?)
Mike1974
Nov 5, 2014
Tampa area
Yes, or changing it to see if the behaviour changes. In your vid the Z moves back, what would happen with no offset in Z, or change it by +1 or 2"..?
james siffel
Jan 19, 2011
telford, pa
What was the diagnosis? Im guessing the third offset callout, the machine is positioning itself in relation to the quadrant for the nose radius.
