Nerdlinger
- Aug 10, 2013
- Chicago, IL
Hi Everyone,
Parts are moving in my chuck. We refurbished the serrated jaws to no avail, so we started looking into the clamping force. If we run the calcs on hydraulic pressure, actuator surface area, and the resulting force on the draw bar our chuck should be producing 20,000 lbs of "total clamping force." It is a four jaw chuck, so 5,000 lbs for each jaw?
We have a small hydraulic force gage and when we put it between two jaws I would expect to see 10,000 lbs, but are getting a little less than half of that. (see attached pic.) I figger we are either getting about half of the clamping force we should be OR I am thinking about this wrong and for some reason we should be expecting to only get about 5,000 lbs with a force measuring gage.
Do you think we should expect to get about 10,000 lbs or 5,000 lbs when measuring this way? I think it should be the former but I am often wrong.
Thank you for your help!
