Metric Threading on a 1954 Series 61 Imperial Monarch
nt1953
Sep 4, 2004
Huntsville, Alabama
Once again I have needed the ability to cut metric threads on an Imperial lathe, so I made 4 gears to be able to cut most metric threads. Using the 25T gear that was already on the lathe (top left gear in the picture below) along with the 4 aluminum gears shown in the second picture I can cut most of the metric threads I might need to cut with acceptable errors. Gear selection, quick change gear box setting, metric thread, and error are shown in the table. Note that the error is not in percent, if you want percent move the decimal two places to the right.
nt1953
Sep 4, 2004
Huntsville, Alabama
Just in case it was not clear, the gears are used one at a time to replace the existing 25T gear at the upper left.
Now that I have cut some metric threads using one of the aluminum gears, I have noted that the tooth loads are much higher than what I had when I made a similar gears for a 16" South Bend. The higher tooth load means that it is likely that if I use the gears very much, I will need to remake them using steel.
johnoder
Jul 16, 2004
Houston, TX USA
Lead screw reverse and leave half nuts engaged?
nt1953
Sep 4, 2004
Huntsville, Alabama
When cut the last metric threads, I did leave the half nuts engaged and reversed the lead screw. However I have also used the method Ox Tool shows in this video:
