kitno455
- Jul 9, 2010
- Virginia, USA
Let's return to the question Roger posted. Roger, I assume you have the normal 24 tooth stud gear, 66 tooth gearbox input gear, and the 4 to 224 TPI gearbox. Given that the gears on the banjo have a fixed center distance, your only simple choice is to swap the stud gear. If you replace the 24 with a 34, you will turn the leadscrew at 1.417 times its normal speed. This will make the leadscrew act like it is 5.647 TPI, which is 4.498 mm pitch. Given the ratios in the box, that will enable you to cut 12 common metric pitches with only .047% error:
TPI MMPT %ERR
144 0.25 0.047
80 0.45 0.047
72 0.50 0.047
48 0.75 0.047
40 0.90 0.047
36 1.00 0.047
24 1.50 0.047
18 2.00 0.047
12 3.00 0.047
9 4.00 0.047
8 4.50 0.047
6 6.00 0.047
That's close enough that it will be masked by the wear in your leadscrew, and would suit most uses.
If you instead use a 33 tooth stud gear, the leadscrew is like 5.82 TPI (4.37mm), enabling 5 more pitches with somewhat worse error (.214%)
TPI MMPT %ERR
28 1.25 0.214
20 1.75 0.214
14 2.49 0.214
10 3.49 0.214
7 4.99 0.214
These are likely good enough for general fastener use. If you'd rather have lower % Error on those pitches, you'll need a two gears instead.
With a 38 tooth stud gear:
TPI MMPT %ERR
23 1.75 0.082
11.5 3.50 0.082
With a 26 tooth stud gear:
TPI MMPT %ERR
22 1.25 0.061
11 2.50 0.061
5.5 5.00 0.061
5 5.50 0.061
Check the pitch of your existing gears. I expect they are 18DP, 14.5 PA (like the 9" workshop), but .5" face width instead of .375". Anything you use will have to match.
Hope this helps!
allan
TPI MMPT %ERR
144 0.25 0.047
80 0.45 0.047
72 0.50 0.047
48 0.75 0.047
40 0.90 0.047
36 1.00 0.047
24 1.50 0.047
18 2.00 0.047
12 3.00 0.047
9 4.00 0.047
8 4.50 0.047
6 6.00 0.047
TPI MMPT %ERR
28 1.25 0.214
20 1.75 0.214
14 2.49 0.214
10 3.49 0.214
7 4.99 0.214
TPI MMPT %ERR
23 1.75 0.082
11.5 3.50 0.082
TPI MMPT %ERR
22 1.25 0.061
11 2.50 0.061
5.5 5.00 0.061
5 5.50 0.061
Hope this helps!
allan
