Milling 75A duro polyurethane sheet?
Terry Keeley
Oct 18, 2005
Toronto, Canada eh!
Need to make some 1" diameter "spiders" for a lovejoy type coupling out of 8mm (5/16") PU sheet. Was going to have them water jet cut but only need a few pcs so was thinking to maybe cut them out on the mill.
I've turned some of this stuff and it was a PITA, sharp HSS worked best. Any ideas for mill cutters? Techniques?
In short it's a PITA material to m/c
I used YG uncoated HSS (they're almost ''wear gloves to change'' sharp) with a degree of success, but found Onsrud down cut router cutters better.
I stuck the parts down with double sided scotch tape, and didn't cut through - left about 10 - 15 thou and trimmed that with a knife
If you can get them water cut - do it!
Something like this?
Ever try to freeze the stuff first?
Generally grinds better than it cuts. I have cut out shapes with a knife and then ground them to the correct shape on a drill press using an abrasive spindle. For the shape I glued on a printed template. Pretty rough method but it worked for me.
Yes, grinding works good. I use a Precise (Brand) electric grinder with 1/4 shank carbide burrs. Grinding removes material with less deflection.
I have made a holder for the Precise grinder that goes on my mill, so it works as a poor mans jig grinder.
Chuck
We needed to machine a lot of urethane for press tooling at Toyota. Tried freezing, neat oil, sharp tools etc. Grinding always gave the best results. It's really dirty.
