Bakafish
- Feb 21, 2022
I picked up an older, but functioning Akashi HH-140 (bought out and also sold by Mitutoyo) portable hardness tester set made in the late 90's that was complete except for the manual. I was able to get some basic readings from it, it came with two test plates and the reading seemed to be within the ballpark, but either the pressure I exerted/technique is wrong or it needs to be calibrated as it was off about 5%. The menu system is a bit inscrutable due to its primitive display, and before I attempt to reverse engineer it I thought I'd reach out to you guys.
My experience with Mitutoyo in getting information on discontinued items has been poor, I collect a lot of older stuff here in Japan and documenting it is often difficult. I'm hoping for a miracle from you guys. I can provide pictures if it is helpful.
