Hello,
I have a small TOS Mn80 Lathe. I bought it second hand in 1996 with my redundancy payment, I have not used it very much. I noticed a strange sound that rises in pitch when the saddle was moved towards the tailstock end. The sound is a bit like running your thumb along the teeth of a comb and it rises in pitch as it goes, and the saddle also gets tight on aproaching the far right end especially if the saddle can travel further after removing the tail stock. The saddle is very tight at the end until I move it back to the left and the sound decreases in pitch as the saddle moves back to the left, like a Piano ! If I turn the Lead screw slightly and repeat the travel along the bed, the sound changes, at 180 degree rotration of the Lead screw, there is no sound until the saddle gets near the tailstock end, also, If I Oil the lead screw threads, this also reduces the tightness and noise. so I think it may be Half Nuts not clearing the lead screw, I can understand that this may make the noise but not the tightness. There is no diagram in handbook. .
Initially, I thought it was the gear on the rack causing the noise and tightness as that's what I was turning, but the gear on the rack has slight and even play even when the saddle goes tight so I don't think it is. Only recently did I discover the Lead screw may be the culprit. I would like to know how to disassemble the apron ( and if possibly get it back together ! ), there is no maintenance manual for this lathe as far as I know, I only have a general user manual and diagrams showing setup tolerances when the machine was new.
Does anyone have any sugestions on what could cause this problem and what may be the cure. I did not want to pull it to bits and loose all the setup tolerances as it is working ok at the headstock end, but I don't like it when I know something is amiss. I would rather watch someone who knows what they are doing, and learn.
Trevor
Trevor
