This will be somewhat of a guide for anyone removing model C spindle, oil pump disassembly, shift forks and reverse shaft.
My lathe is a 1944 14C, more documentation on it here. I made a seperate thread as I wanted to have an easily searchable guide in case anyone has similar issues.
I removed the spindle for 2 reasons; the headstock oil pump stopped working and there was an issue with the gear selector which I already knew about. After repairing my oil pump I get a drop every couple seconds in sight glass. I get a drop every time out of sight glass when pump plunger is manually depressed. If you have less I would suggest your pump filter needs to be replaced/check valve stuck etc.
You can remove the oil pump without pulling the spindle. I would suggest 1/4" drive ratchet, some extensions and a flat screwdriver bit. It's a lot easier reinstalling pump if you replace the fillister head screws with 1/4" unc cap screws around 3/4" long for memory. I wouldn't advise pulling the spindle to just remove your oil pump, unless you have other issues going on.
While on topic of tools and supplies I would have following on hand;
Good hex keys
Good flat screwdrivers
3/8" drive hex bit sockets sizes 1/8" > 1/4"
Ideally a C spanner for spindle lock nuts
Maybe a slide hammer or ability to make something for reverse gear pins they're tapped 1/4"UNC . Mine weren't tight but yours could be.
Assorted set screws. It would be nice to replace with new. 1/4"UNC x 1/4"lg extended tip for gear retainer rings 92505A533 mcmaster
Diesel or kerosene for washing headstock
3/16" thick felt for oil pump pickup
Ideally new suction and outlet check valves for oil pump
Testing oil pump flow to ensure no clogged metering valves; removed oil supply line second in from right (only one without metering valve) and manually stroked pump;
I marked everything and quickly engraved match marks to speed up reinstall. Nothing is critical timed. Good time to mention not to try running the lathe with headstock cover off. Double good idea to isolate the power at this point too.
Bearing preload collars. These shouldn't be overly tight but your situation might be different. My c spanner not really the right size but it worked fine. Single set screw with bronze pad.
Remove both threaded collars, then there is 2 spacers both keyed 180*. They should be a slip fit. Remove them and the 2 woodruff keys.
Large reverse gear - top of photo, rearmost of headstock has one 3/8UNC set screw and one woodruff key. Small reverse gear - next one towards spindle nose has 2 pins. There should be a snap ring to retain them, but mine has lockwire.
The next gear after that (not pictured) - large spindle drive gear has a set screw which secures the gear to the small spindle gear carrier. You do not need to remove this set screw.
Small reverse gear retainer pins 1/4"UNC threaded for puller. I think these are a transition fit, you could likely use a bolt and some vice grips to extract if they were tight.
Next is the bull gear retainer ring. 3x 1/4UNC x 1/4 extended tip set screws not equal spaced - maked in blue in my picture. I marked mine as I had to tighten all of them when I got the lathe -the PO left practically every set screw loose in the headstock. More on that later
Remove 2x slotted stake screws front "oil deflector" 3&9 o'clock
Good hex keys
