candeservices
- Jul 8, 2022
- Houston
Yes but, they are supposed to flex axially and Not radially.Are they called flexplates because they are meant to flex?
Check out the fretting where the torque converter pillars bolt up. That thing has some big time misalignment going on. Bell housing machined on the piss?Second one in 4 years/50k mi. '11 Dodge Caravan 3.6L. What's going on with this material, does it need to be annealed? Cheap part, but it costs $600 to get to it. OEM MOPAR. This was supposed to be the updated part. I haven't taken a file or center punch to it yet, but it looks like glass....flex plate not flexing, apparently.
That should kill the pump long before the flex plate fails.This may not be obvious on removal, but it should be apparent on replacement. If the T/C is all the way in when bolted up, you should need to pull it out a bit to mate with the flywheel. If there is tension there upon installation, over time this could happen. (in my theoretical mind - cannot say real world)
And @eKretz are correct..... If the engine and transmission are not perfectly aligned the plate will crack at those positions.
Indicate around the, what, 'reaction shaft' on front pump housing, or remove the front pump housing and use a dial indicator in the openingHow did you figger out the amount and direction of mis-alignment on the 904?
A dial indicator on the input shaft - and reading on the pilot bore (more likely the OD I guess) in the crank?
Leave the pan off so that you can spin the input shaft assy?
Not that the input shaft is that solid, but prolly gits you in the ballpark?
Think Snow Eh!
Ox
Think Snow Eh!
Ox
Pilot or OD *and* the rear face of the crank, I think.
Something has to turn.
Sport:
So you put your indicator on the crankshaft then?
Oh heck, what am I thinkin' - you just need to mag it to the fly ... uh - flexplate and then inch that around.
WAY easier than I was envisioning!
Of course all you need is an empty tranny and the pump housing to doo that...
Well, that would be way easier on this tranny with the ring gear on the flexplate than on your 904 - to "inch" it around that is.
When I worked in the tranny shop in 1986, my cousin sold a trans brake set-up.
(seems like maybe ATI, ATS, or sumpthing like that?)
And so I wouldn't be surprised that a few slip and slides may have went behind a Chrashler motor here and there, but I don't think that any of those 2 speed miracles that went out our door had iron cases nor rear pumps.
I've never [knowingly] even seen one of those animals to date.
(But there was a 345 W motor on a stand upstairs - so that was cool! - not ours tho - cold storage)
Think Snow Eh!
Ox
Notice
