dll6
- Apr 23, 2005
- Washington
Any idea if MOBIL VELOCITE 3 Spindle Oil is the right stuff?
The manual calls for "super multiway 2" I hope that crosses because I bought 5 gallons last year
No drawings here. It’s been 25 plus years since I last touched one of those. You have to remove the drive belts and the giant lockring. A hammer and drift job. The cartridge is held in by the largest bottom flange. There may be some coolant nozzle parts to remove to get to all bolts. The close fit in the head bore, combined with the o-rings, makes it kinda tough to get out. Usually involves prying or jacking to get it moving.
I bought the machine because I thought it a sturdy design, I always planned to retrofit the control if it turned out to be a good donor, the jury is still out .... This is my first NC machine.The MX1 never had firmware for rigid tapping. To get rigid tapping would require a control retrofit. You’re better off dumping the machine and buying a newer one with rigid tapping if that’s a real need.
..If you mean you loosened the nut on the drawbar, then you need to tighten back to the original position or close. Having it loose reduces the retention force of the drawbar because the belleville spring stack will not be preloaded the correct amount.
I agree that a good retrofit option is hard to find and even harder to implement. Ive never been accused of being a quick learner, but I am persistent, I rarely give up. Ive not found any retrofit kits I'm happy with. In working with this machine I'm becoming very familiar with its ladder design and am leaning towards retrofitting a newer yasnac or maybe fanuc control to the system. I've no experience with the fanuc controls yet.The machine is solid but IME, retrofits end up being crap. I long ago swore off working on them because they universally were so poorly done. Very few folks have the knowledge and understanding of robust PLC programming to make safe and reliable logic for control of the machine functions like a tool changer or others. Then they are rarely documented well. All of that conspires to make the machine unreliable and difficult to service fir anyone other than the person that did the retrofit.
......In researching rigid tapping I agree its place is in parts with repeated small threaded holes and takes extremely accurate synchronization of the Z axis to the spindle rotation.
I've seen those guys posting in their forums too. There the ones I figure I'll get the hand-me-down original Yasnac or Fanuc controls from, for cheap, if I go the upgrade route.
Notice
