Dear All,
We are in a process of setting up an MDT centre in our area. And currently we are intending to install the following machines in the workshop:
• CNC VMC (3000x1200x700)
• CNC HMC (1900x1400x900)
• CNC VMC (1900x1400x900)
• CNC VMC (1000x550x450)
• Universal Milling Turret Type (1000x300x450)
• Universal Milling Bed Type (1100x520x600)
• CNC Turning Centre
• Radial Drilling (1350)
• Lathe (Length 1000)
• NC Surface Grinder (800x400x300)
• NC Surface Grinder (300x200x200)
• CNC EDM (75 amps) (2500x1350x700)
• CNC EDM (75 amps) (1450x950x550)
• CNC EDM (50 amps) (700x500x400)
• CNC Wire Cut (5 Axis) (1000x600)
• CNC Wire Cut (5 Axis) (600x400)
• 3 D Scanner
• Rapid Prototyping
• Heat Treatment Facility
• CMM
• Matching Press 100T
• Surface Texturing/Treatment Facility
• Crane 20T
• Tool Presetting Equipment
Now,
--could you pls. provide me with some kind of layout plan for these machines ?
--What kind of airconditioning is needed for these machines (normally)??
--Few of these machines are having capacity of workpiece of as huge as 3 Tons.so, should we build an over-head crane for the mould assembly??
--Are there any fork lifters (Man Operated) for these machines ??
--Will we be needing seperate compressors for the pneumatics of these machines???
but the most imoportant thing right now is the layout plan for approx 30,000 Sq ft shop area (if needed) for these machines ...
CAN ANYBODY HELP ME>>????
• 3 D Scanner
• Rapid Prototyping
• CMM
• Crane 20T
Now,
