Hi,
I have been given what I believe is a Hepworth tracer. I haven't used one before, so I would like to get some input on how it should be mounted on the monarch 14C. The monarch's cross slide is quite short, and I think to get reasonable support under the tracer the main tool post/compound would be right close to the tracer tool post.
I am thinking making a sub plate for it might be the go... or its own dovetailed cross slide mount? Not sure. I would like to have it reasonably quick to install/remove. Curious to hear other people's opinions on optimal placement. The bolt sticking up in the cross slide is for the cross slide nut. This needs to be fixed regardless when I make a new nut so it will be flush in the future.
Underside of cross slide for ref
Thanks,
Will
Thanks,
Will
