Tyrone Shoelaces
- Apr 19, 2006
- Manchester, England
I was referring to the clearance holes in the jacking screws in the sheet metal cabinet. Why you would need jacking screws at the tailstock end of the bed as well is a bit of a mystery. The only reason I can think of is that maybe you could buy the lathe without the cabinet so you could put it directly onto a work bench. You would possibly need the jacking screws in the bed then.I think there may be a definition issue here. My Harrison m300 13x40 lathe, made in England has four feet. One at each corner. There is a bolt to raise and lower that corner and a empty hole nearby to allow a bolting down anchor to go down into the floor.
Bill D
Edit: I just realized Tyrone is talking about the cast iron bed of the lathe itself not the base cabinet. I have no idea what holds mine down onto the heavy base cabinet. When I asked about moving it I was advised not to separate the two as they are adjusted and then putty or something bonded to stay in place.
The clearance holes in the jacking screws in the cabinet are normally put there to facilitate holding down bolts or anchors. Wether you choose to use them for that purpose is up to you.
It’s usually a good idea not to separate a lathe from it’s base/cabinet.
When I was an apprentice all the lathes at the college I attended were all installed on adjustable vibra-mounts. One of the projects we had to do involved drilling and boring two holes in a block of steel in the lathe. It involved the use of a four jaw chuck and tool makers buttons. It meant the job was out of centre in the four jaw chuck and therefore out of balance.
One day while we were waiting for the instructor to arrive one of the dickheads in the class thought it would be a good idea to put the lathe on the top speed and switch it on “ just to see what would happen “. It was one of a row of brand new “Harrison “ centre lathes.
Well what happened was the lathe began rocking slightly than rapidly began to shake alarmingly. Just when I was starting to panic one of the smarter kids threw the isolator on the wall before the lathe actually fell over. Just saying.
Regards Tyrone.
