seiner
- Jan 9, 2008
- Valdez, Alaska
Ok, so i didn't really crash two lathes or even one lathe but I thought about it, a lot.
I have two lathes set up facing each other, just turn around, step to the left and go to work. Lathe #1 The Green Meanie 20x96 Reed Prentice. #2 14x48 spanish Clausing. Job #1 boring 2 2.833" id x 1.00" pockets for bearings in 304ss, in a part i have 6 hours into already. #2 Simple pin 15" long x 1.5 with a 2" head and .375 cross hole. also 304ss.
So I had the wrong jobs in the in the wrong lathes, heavy cutting in the small lathe more precise stuff on the big lathe. I've got a lot of time on the big lathe and like it so that is where i was doing the bearing pockets when the pin job came in from a local welding shop. I don't have any time on the Clausing at all and in fact I am still figuring things out. It seems pretty nice compared to the 73 year old iron I'm used to but, it sure won't take a cut like I am used to. I tried 600sfm, .003ipr, .01doc and got horrible chatter, dropped cfm until it quit at 150smf and pushed doc up to .025. Meanwhile the Green Meanie is boring at 250sfm, .015ipr and .025doc not even breathing hard. Same insert on both in Aloris tool holders.
So Start long cut on the Clausing, turn around, measure bore, Take two cuts, turn around and pull stringy swarf out of the Clausing, turn around, measure bore, take one more cut, turn around, pull chips, finish long cut, Repeat.
Not very hard or even challenging but stressful for me none the less. A much better use of time than I am used to.
I really don't like 304.
Need to relevel the Clausing to get straight parts.
Need to install new cross slide on the Clausing.
Need to figure out this high sfm, light feed thing.
should probably do my hogging on the Green meanie. (It is really good at that)
And a couple of photos;
View from the Clausing;
View of my machine corner of the new shop.
Hard day at work on May 15
